Axels..Posi?
Old May 10, 2003 | 02:28 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Axels..Posi?
Hey, how can you tell what spline axles you have? Don't they make That one $100 posi for both 26 and 28 spline axles.
Old May 10, 2003 | 02:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
1989 was the year GM switched from 26 to 28 spline, but I beleive it was late '89. SLP sells a USED posi called a Zexel Torsen Limited Slip for $100 that was removed from Z28s and Trans Ams during the SS/Firehawk conversions. They only come in 28 splines.
Old May 11, 2003 | 12:51 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Ok, will i have a 82 z28, its supposed to have stock 2.73 gears. I did that driveshaft test and it showed 3.23 It is a peg leg rear. It would cost me $200 to get posi, is it worth it? How much will I gain? Also, how do you tell what spline axles you have? Thanks
Old May 11, 2003 | 01:48 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Pull out an axle and count the splines. You probably have 26 spline axles if the rear is stock. My friend went with an Auburn Posi on his 82 T/A but that posi was more than $300.
