700R4 drops out when shifting from 2-3
Old May 22, 2003 | 11:39 AM
birdboy86's Avatar
Car: 91 Z28
Transmission: 700R4 stock
I have a 86 T/A and the 700R4 that's in there drops from 2nd back into 1st and will not shift into 3rd. I am considering switching to a 400. Before I do I would like to know if there is a simple fix to the 700 and if I switch to the 400 would I have to make any major changes or mods for the switch?
Thanks for any and all help.
Old May 22, 2003 | 01:05 PM
camaropowerZ28's Avatar
I'm not sure what's wrong with your tranny, but I do know that you probably wouldn't want a 400. You would be better off getting a th350 with a 9inch tailshaft. I believe that with the 400 you would have to lengthen the driveshaft.
Old May 22, 2003 | 02:13 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
there is alot that has to be done to use a 400
the kit by hurst includes the crossmember and torque arm bracket
then you will need to have your driveshaft modded
you will also need a turbo 400 yoke
and a kickdown switch
its worth it though, IMO
Old May 22, 2003 | 06:15 PM
paintshooter's Avatar
my camaro did the same thing I had to get it rebuilt to fix the problem.
Old May 27, 2003 | 09:03 AM
birdboy86's Avatar
Car: 91 Z28
Thanks for your help and suggestions on the problem. I've found a shop that has rebuilt and will rebuild transmissions either stock or highperformance. I can get a 700R4 already rebuilt with corvette servo's, shift kit, teflon bushings....fully tricked out for $595!!!!!!!!!!!!! He deals with any and every transmission out there.. He is located in Tarpon Springs Florida (Street/Strip Transmissions) ph# (727) 487-3020 or (727) 942-7900.
Hotrodboba400
Dec 10, 2019 07:07 PM
Vojtush31
Oct 11, 2015 01:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
