VSS sensor in a manual???
Car: 1987 IROC-Z
I am wondering where the VSS sensor is in an 1987 305 tpi 5 speed manual tranny?
My speedo stoped working about 2-3 days ago and every time I drive for about 5-10 minutes it throws a code 24.
I want to know if it harms the car when I drive it this way?
and is it a pain to replace the VSS?
thanks everyone.
thanks everyone.
Car: `86 SS / `87 SS
The VSS is in the speedometer.
Fix your speedo / speedo cable / speedo gears problem and the code will stop occuring.
I have had that problem a couple times with my cars and that fixes it.
Good Luck!
Car: 1987 IROC-Z
when I try tot ake off my gauge cluster to get to the VSS sensor, it doesn't come off all the way, I know the speedo cable is holding onto the speedo gauge, but I cannot pull the gauge cluster out far enough to disconnect the speedo gauge, is there another way to aproach this? and do I need another speedo or can I just buyt he part and swap them out?
I'm just glad it isn't int he tranny like auto's
manual and auto firebirds got in-trans VSS the same year; 1986 I believe.
It's easier and quicker to change a VSS in a 700-R4 or T5, than to pull a speedo.
If it's the cable holding the speedo, press towards yourself on the retaining clip; usually the top or bottom of the clip is what needs pushed on.
Matthew
FormulasOnly
Sep 10, 2015 09:07 PM
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
