Carrier change....
Old Jun 2, 2003 | 01:36 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Carrier change....
I'v got a 4th gen rear "96" and it dose not have the torson carrier in it well I got a takeoff from SLP and I am going to be putting it in this week some time what I am woundering is being that I am not changing the gears just the carrier if I am going to need to set up the gears or not? I would think all I will need to do is make shure I put what shims came out back in there same spot and that should be that right?
Any input would be great thanks!
Also what are the tourq specs for the ring gear and the caps?
Old Jun 2, 2003 | 05:27 AM
ede's Avatar
ede
you should be able to swap the ring gear from the old to new with no problems. i'd use new bolts on the ring gear, check back lash and contact pattern.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
