Rear Whining/Whirring Noise
Old Jun 5, 2003 | 06:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Rear whines/whirrs, especiallyu during decelleration. I've determined from searching the boards that this noise is probably a loose pinion nut in the rear end. This is a 3.08 Posi that I just got about 2 months ago used.
My questions -
(1)Does tightening this pinion nut solve the problem for a relatively good period of time (will it buy me a year?), or does tightening just buy a few weeks/months (a temporary fix to a permanent and real problem)?
(2)Also, I'm reading that this is maybe a delicate operation - as I have no rear end experience at all, I'm guessing I should have someone do it for me? What would a shop charge for that?
(3)Should I stop driving the car immediately because of this, or can it hold out another 500 miles (next paycheck)?
Old Jun 5, 2003 | 07:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. Impossible to guess. Might not do anything at all, might fix it more or less permanently, might ruin it.
2. Definitely stay on the delicate side. A breaker bar at least 2' long along with a yoke holding tool of equal or greater length, or an air impact capable of 350 ft-lbs or so. I'd avoid hammers though, much too delicate an operation for that.
3. It's real easy to check.... disconnect the drive shaft and see if you can move the yoke or the pinion gear around. If you can move it around, tighten it. If it seems tight, you have other problems.
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
