Part # for speedo gears (T5)
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
Does anyone know the part number for an 18 tooth driven gear that fits on a 1992 T5. My local GM dealer can't find it.
PAT...
PAT...
https://www.thirdgen.org/techbb2/sho...r+change+gears
all i could find...maybe that helps a little
Car: 1987 IROC-Z
Thanks, but I've seen that post before and the only part # listed are for the 700R4 tranny. The T5 use different parts.
Someone on that site should know ???????
PAT....
PAT....
So far, I have seen these choices for the T5:
Drive gears:
6T
7T
8T
9T
Driven gears:
18T
19T
20T
21T
22T
FYI, this equation is if you know what driven gear you have:
Drive Gear = (.0495835 * Tire Diameter * Driven Gear) / Gear Ratio
Drive gears:
6T
7T
8T
9T
Driven gears:
18T
19T
20T
21T
22T
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
