7.5 inch rear to 7.65
Old Jun 8, 2003 | 06:51 PM
dantheman1998's Avatar
Can the internals of a 7.65 inch rear fit in the 7.5 inch rear? i know the gears do so why cant the posi? Does this make it stronger and how much a setup like this will handle.
Old Jun 8, 2003 | 07:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is the same thing. Totally interchangeable in every way (except for the 2-series and 3-series issue, and 26-spline axles & side gears vs. 28-spline). I have no clue why the factory "changed" the designation for that model of rear without changing anything about it.
Since they're the same, it does not make it stronger.
28-spline stuff (90 up) is stronger than 26-spline (88 back) in the area of axles. The gears and carriers are the same.
If you want to strengthen your rear, weld the axle tubes all the way around where they join the housing; use a stud girdle type of cover; use a solid pinion bearing spacer instead of a crush sleeve; use synthetic fluid.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
kyleb24
Aug 15, 2015 08:24 AM
