Clutch master cylinder vs hydraulic assembly?
Old Jun 8, 2003 | 10:01 PM
David Trimble's Avatar
While under the dash today replacing my accelerator cable I noticed the pushrod to my master clutch cylinder looked a bit 'wet'... when I pushed down on the clutch pedal I was rewarded with brake fluid bubbling past the boot.....
Now the slave cylinder's been replaced a few years ago already by a garage....... but in scanning thru the board I see those talking about replacing the entire hydraulic assembly rather than just one of the cylinders. Also I noticed in the manual that the system is to be replaced as a prebled unit... however the garage obviously replaced the slave cylinder and bled it with no problem...
So my main question- which is more advantagous- replacing the system or just going ahead and replacing the clutch master cylinder?
Thanks!
Old Jun 9, 2003 | 12:49 AM
25thanniversZ's Avatar
I did the same on mine...individualy, took a while to bleed it but I got it done....let gravity do the most part
Old Jun 9, 2003 | 12:40 PM
I think my replacement slave cylinder has a bleeder screw- I'll have to get under the car to be sure.... but basically I would just need to crack it open and let it sit for a while, topping off the reservoir once in a while until I see fluid coming out of the bleeder?
Old Jun 9, 2003 | 03:24 PM
yes....put the cap back on and pump the clutch........remove cap let it sit...put back pump...ect.....if its got a bleader screw more power to ya
Old Jun 9, 2003 | 03:27 PM
'cap' as in the reservoir cap? Basically you just 'work the bubbles' out by filling, pumping, waiting, refilling, repeat 5-7 times or so?
Old Jun 9, 2003 | 08:15 PM
thats the idea but more than 7 times likely
Old Jun 9, 2003 | 08:55 PM
Gotcha Thanks!
devilschariot
Feb 25, 2016 03:08 AM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
