th350 to a 173ci v6
Old Jun 9, 2003 | 06:58 PM
EvilAsh's Avatar
th350 to a 173ci v6
:rockon: I have a 82 camaro sport coupe w/ the 173 ci (2.8l) 60 degree v6. Currently it has the th200 trans. I plan to replace it w/ a th350. I know the overall length of both trans are the same (I can re-use the th200 driveshaft). Do the th350 & th200 have the same bolt pattern?
Old Jun 9, 2003 | 08:05 PM
25thanniversZ's Avatar
yes they shpuld be...if any doubt check them back to back when you pull the 200
Old Jun 9, 2003 | 11:25 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the TH350 will not fit that engine because it does not use a SBC bolt pattern!!!!!
also, you can not make an adapter plate because there is WAY too much of a difference
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
