Some rearend question
Old Jun 9, 2003 | 06:37 AM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
i was just wondering which gears came on a stock 84 camaro z28. Also what would i gain from getting, say, 3.73 gears. what do the numbers mean like 3.73 or 4.10, and which is the best. do they increase top speed or they good for dragging? thanks alot
Old Jun 9, 2003 | 08:08 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
the higher the number say 4.11 you will see an increase in you 0-60 acceleration, or possible wheel spin. These will also lower the limit on your top end speed. Also, use more gas.
Stock an 84 might have come with 3.23 ish, the reason I say ish is because I am not sure if it would be a 10 bolt or a 9 bolt. It is also possible that you have some other ratio. Check your rpo # to make sure.
Old Jun 9, 2003 | 09:12 AM
Drakar's Avatar
It was a 10 bolt rear and 3.73's came with the L69 motor and 5spd standard, was option if you had an Auto/L69 combo and was optional for LG4's
Old Jun 9, 2003 | 12:13 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i know on my 84 TA it was a 3.73 but i don't think it's a posi, unless it's f***ed up.
Old Jun 10, 2003 | 09:10 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
To give a the best definition of what the numbers mean and to explain how they effect your car and why a higherr nubmer will accelerate faster than a lower number is simple.
IMAGINE, a lever, make it a teter-totter and on one end you have a fixed length of 1 Foot. The other end is variable, in this case a 3.73. That 3.73 Feet in this case would can lift more weight easier than say 2.73 Feet.
In effect what is happening is the higher gear ratio lets the engine spin up faster with less restance just like a longer arm on a lever.
The down side as we all know is if the gear ratio is too high like a 5.00:1 then your engine speed will be about 4000 RPM at 70 MPH. Its GREAT for doing burn outs, but your engine would not like to run at that speed for a long time, and your 1/4 mile times would drop because you would run out of engine before the 1/4 mile was up.
does that help?
John
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
