Got early 70's 12 bolt in my car,whines louder then my richmond geared 10 bolt.
Old Jun 14, 2003 | 08:38 AM
redtail2624's Avatar
Car: 88 TA
Engine: 383 Converted LT1 intake
Transmission: TH350 3500 stall
Axle/Gears: 12 bolt 3.73's
Ok heres the story i put 3.73 richmonds in my 10 bolt last year and they blew this year from putting on to wide a tires.So i went to the junk yard that a good friend owns and found a 12 that they just took out of a 84 camaro,Yes someone already did all the fab work for me sweet.I checked it inside and out before i put it in and everything looks great bearing gears which i am almost positive are aftermarket.I take it for a ride for the first ride last night and those gears whine pretty loud,on accel ,deccel,coast all the time over like 40mph. I cant move the pinion what so ever so i am pretty sure there is enough preload on it cuz i changed the pinion seal and just turned it a little more than it was before and it felt nice.I also put in sphoon lca's at the same time.why would it whine like that it sounds like a school bus rearend.My only thought is cuz its a 12 bolt and the gears are bigger and they are aftermarket which i know most of them whine.Any thoughts or suggestions would be great.
Old Jun 14, 2003 | 02:28 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Time to pull the cover and paint the teeth. My 12 bolts and even the 14 bolt are quiet as can be except over 120mph then they whine like a mother. You should have a little play on the pinion before it catches if not the mesh is way too deep.
Old Jun 14, 2003 | 04:54 PM
Car: 88 TA
the backlash is perfect i checked it out.I will try rolling the pattern and see what i get.
hectre13
Dec 11, 2023 08:14 AM
9192camaro
16
Feb 3, 2019 12:21 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
MENINBLK
Aug 5, 2015 11:58 PM
