305 tpi to 350swap what about tranny?
Old Jun 15, 2003 | 07:48 AM
ajm_shorty's Avatar
Iv got a 305 TPI and am now going to a 350 Carb...I was wondering if my tranny will shift ok with no more computer in the car? and before the swap is there anything i should know and any problems i may run into.
Old Jun 15, 2003 | 09:10 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The 700R4 isn't controlled by the computer. It's controlled by the Throttle Valve cable. The thing should happen with the new motor. You may have to replace the TV cable. I'm not sure if they are the same length for both motors.
Old Jun 15, 2003 | 09:18 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
With out computer you wont get TC Lockup. You will have to manually engage the lock up.
Old Jun 15, 2003 | 10:09 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Both are correct. The transmission shift points are in part controlled by the TV Cable so getting it properly installed on the carburator is essential. You will also need to devise a way to lock the converter clutch up. There are several methods, do a search.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
