84 rear in 89
Old Jun 15, 2003 | 09:34 AM
89formula35O's Avatar
84 rear in 89
would a 84 Z28 HO 5 speed 3.27 9-bolt posi disc fit in a 89 formula?
thanks
chris
Old Jun 15, 2003 | 10:16 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes. All thirdgen rearends, whether it be a BW 9-bolt or an American Axle/Saginaw 10-bolt, use the same mounts. If you are going from disc to drum, or PBR calipers to cast iron calipers, the parking brake cables will vary as will the proportioning valve.
Old Jun 15, 2003 | 10:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sure, except that there's no such thing as a 84 9-bolt. Either the rear came from some other car, or it's mis-identified. See "features from the future" near the bottom of this post.
https://www.thirdgen.org/techbb2/sho...hreadid=184623
Old Jun 15, 2003 | 11:30 AM
hmmm ill have to ask the kid about the 84 part, thanks!
Old Jun 15, 2003 | 04:01 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/tech/techdb.shtml
84 Z28 M5 L69 V8 9.5:1 5.0 (305) 190@4800 240@3200 4bbl HO 3.73 10 bolt
if it does have posi and disk brakes that would be a nice rear end.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
