1982 FIREBIRD S/E 200c TRANS HELP !!
Old Jun 22, 2003 | 02:42 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
HAVING SOME PROBLEMS WITH MY 200C TRANS
FIRST IT'S LEAKING IN THE INSPECTION COVER TO WHAT I'VE BEEN TOLD ITS THE FRONT SEAL.ALSO THE BUTTON (LITTLE SILVER BIRD LOGO)ON THE SHIFTER IS STUCK INSIDE THE SHIFTER IS SOMETHING BROKE ? AND FINNALY THE 'BIG QUESTION WHICH ONE OF THESE CAN I PUT IN MY 82 S/E PLEASE HELP THANKS ?
A.T., TH350, w/multifit case, 1 wire lock-up plug harness
A.T., TH350, w/multifit case, 2 wire lock-up plug harness
A.T., TH350, w/multifit case, 3 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/Chev bolt pattern; 1 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/Chev bolt pattern; 2 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/Chev bolt pattern; 3 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/o Chev bolt pattern; 1 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/o Chev bolt pattern; 2 wire lock-up plug harness
A.T., TH350, w/o multifit case; w/o Chev bolt pattern; 3 wire lock-up plug harnes
Old Jun 22, 2003 | 02:54 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
front seal leaking yes,
and the firebird logo shifter button in my 82 trans am is opposite problem and pulls out completely real easy and it has a long shaft the extends into the handle shaft, i dunno wehy it is stuck out and comes right out. no one seems to know a dang thing about the shifters.
two wire four terminal suqare plastic plug is stock correct on GNM automatics with lockup verters, i think lockup is overrated, i do away with the wiring on any that i come across, too much of a pain for the minute RPM savings that you may get
Old Jun 22, 2003 | 03:11 PM
On Probation
200c trans
Ok thanks.Now i gotta go find me a th350 And someone to in$$tal it.Even more $$$ outta of my pocket.Stupid economy
Old Jun 22, 2003 | 03:17 PM
On Probation
200c trans
colton_carlson
Mar 8, 2019 12:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
