454 with 700R-4 trans?
Old Jun 27, 2003 | 11:17 AM
Guest
Guest
Posts: n/a
i know alot of people like to use the TH400 ot th350 with the 454 but has anyone used a 700R-4 is so can the 700R-4 hold up to the HP of the 454?
Old Jun 27, 2003 | 01:40 PM
82camaro's Avatar
Car: 82 camaro SC
How much HP are you talking about? The tranny doesn't care what engine it's hooked to, just how much power it has. The 700r4 can be built to handle quite a bit of power.
Old Jun 27, 2003 | 05:02 PM
Guest
Guest
Posts: n/a
well if i get the 454 i'm going to go all out... bore it .030 over (motor has high mileage) JE pistons, aftermarket world or thickFlow heads, the biggers cam that will fit and maybe one day a blower. but that may be years down the road i'm waitting to way someplace around 600hp maybe??
Old Jun 27, 2003 | 06:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A 600hp BBC with blow a stock 700R4 to peices, same with a stock TH3500 or TH400.
Old Jun 27, 2003 | 06:39 PM
Pro Built Automatics's Avatar
I could build one that takes about 625 horsepower maximum (with a 10" or smaller diameter torque converter), anything after that I would go to a built TH400.
Old Jun 27, 2003 | 07:24 PM
Guest
Guest
Posts: n/a
whats the most a stock 700R-4 can take?
Old Jun 28, 2003 | 07:35 AM
82camaro's Avatar
Car: 82 camaro SC
Stock, depends on the year of the tranny and how much it has already been abused. At that HP level you probably aren't going to need overdrive anyway.
Old Jun 28, 2003 | 12:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Why would you invest a huge chunk of cash in an engine and leave the transmission stock? Even considering it sounds plain stupid to me. People have trahed 700R4's with stock 2.8's.
This isnt going to be a very streetable setup if it does happen so choose the correct transmission for the job. My BB 402 is pushing over 500hp and the transmission I have isnt going to hold up much longer to abuse and its a HD Muncie 3.
Old Jun 28, 2003 | 06:07 PM
EvilCartman's Avatar
Car: '82 Z28
Friend of mine has a 500 HP BBC with a 700-R4 behind it in a 68 Firebird... the transmission was built up a bit so it's holding together so far. Really haven't made any passes on it since there's zero traction lol Getting slicks sometime soon so we'll see after that.
MustangBeater20
Oct 29, 2022 09:20 PM
Kaweh
Aug 19, 2015 07:06 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
