just bought a 3.73 rear
Old Jun 28, 2003 | 05:51 PM
blue305rs's Avatar
Car: 1989 camaro RS
Hey guys i just have a couple of questions, about a rear I just bought off of ebay. It is a posi rear from an 87 trans am with 3.73's. I have right now in my car a 3.08 rear non posi. so i guess my question is how much of a difference should i expect and how bad am I going to kill my gas mileage now with the 3.73's. I have a t-5 transmission by the way. Thanks for any input.
Old Jun 28, 2003 | 06:20 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
what mpg were you getting before?
Old Jun 28, 2003 | 06:27 PM
blue305rs's Avatar
Car: 1989 camaro RS
I was getting about 17-18 mpg with the 3.08's
Old Jun 28, 2003 | 07:04 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
It won't be too bad on the gas mileage if you can keep your foot out of it. You might have a hard time since it will accelerate better and you cna roast the tires easier (not that it's hard anyways).
Old Jun 28, 2003 | 07:59 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
blue
I went from 2.73's to 3.73's and it made a huge difference in acceleration
Old Jun 29, 2003 | 11:33 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
you'll like the 3.73s.
87 T/As didn't come with 3.73s stock, I don't believe.
Old Jun 29, 2003 | 01:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
First thing you should do before you put it in your car is take off the cover and inspect everything and change the fluid. While you're doing that, make a point of looking for the numbers stamped on the edge of the ring gear, or count the teeth.
I'd almost be willing to bet that it doesn't have 3.73s, unless they've been changed. I don't believe any of those cars came with a ratio above 3.42, and those are pretty hard to find, would probably actually have been a 3.45 9-bolt (305 TPI 5-speed only).
Better count the teeth before you pay the bill.
Old Jun 29, 2003 | 10:00 PM
blue305rs's Avatar
Car: 1989 camaro RS
Thank you guys for all of your help. I am going to go july 6th to pick up the rear. They are not the stock gears in the rear, the seller had 3.73's put in. Thanks again for all of your help.
*edit* thanks mdformula
Old Jun 29, 2003 | 10:03 PM
MdFormula350's Avatar
Originally posted by blue305rs
I am going to go june 6th to pick up the rear.
you better hurry up ur 23 days late j/k
good luck with the new rear.
hectre13
Dec 11, 2023 08:14 AM
86IROC112
Sep 7, 2015 01:37 PM
sailtexas186548
Aug 26, 2015 03:32 PM
johanlindgren
Aug 16, 2015 12:16 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
