i have a 88 rs v6 what rearend do i have
i have 3.73's looking for a stock posi that i can rebuild, since im not sure what rearend i have i want to know ring gear size and if my rear is the same as a v8 rear and what spline r my axels?
88
RS
M5,A4
LB8 V6 8.9:1 2.8 (173) 135@4900 160@3900 MFI
gears 3.42
https://www.thirdgen.org/newdesign/tech/techdb.shtml
from the stock gear ratio, sounds like a 10 bolt rear end, which for that year had 26 spline axles, you might want to upgrade to 28 spline axles and then get an slp take off posi.
Differential, O.E.M. Zexel-Torsen Camaro/Firebird
It's an O.E.M. Zexel-Torsen 7.5" & 7.625" differential found in most 1998-2002 Camaros & Firebirds (with 28 spline axles). It will also fit 1982-1997 Camaros & Firebirds (1982-88 requires changing to 28 spline axles).
NOTE: This is a 3-series differential
http://www.slponline.com/view_produc...TNUMBER=64501T
RS
M5,A4
gears 3.42
UltRoadWarrior9
Apr 28, 2020 10:39 PM
