80w-90 or 75w-90
Old Jul 2, 2003 | 06:34 PM
25THRSS's Avatar
80w-90 or 75w-90
Alright I got the stock non posi rear right now with 2.73's, but will soon be installing an eaton posi with 3.42 gears. Which type of gear oil should I use? The manual calls for 80w-90, but should I use something different for the eaton?
Old Jul 2, 2003 | 07:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those are so close as to make no difference at all.
I'd recommend synthetic gear lube and a bottle of posi additive.
Old Jul 2, 2003 | 09:43 PM
25THRSS's Avatar
Thanks, I'm definitely gettin synthetic and the posi additive will go in with the posi. I can't seem to find many synthetics in the 80w-90 form, mostly 75w-90. Know where I could find some synthetic 80w-90?
Old Jul 2, 2003 | 09:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.amsoil.com/products/agr.html
"AMSOIL 80W-90 Gear Lube exceeds the lubrication and performance requirements for gear boxes where API MT-1, GL-4 or GL-5 lubricants are specified. AMSOIL Synthetic Gear Lubes provide limited slip performance. Although generally not necessary, manufacturers' limited slip additives may be used in conjunction with AMSOIL Synthetic Gear Lube."
I've heard of a few people (out of thousands) who had chattering w/o the additive.
Personally, I prefer: http://www.amsoil.com/products/tgr.html
"AMSOIL Series 2000 Synthetic Gear Lube provides limited slip performance. Although generally not necessary, original equipment manufacturers' limited slip additives may be used in conjunction with AMSOIL Series 2000 Synthetic Gear Lube."
I've never known of anyone who had to use the additive with the Series 2000 product.
Old Jul 2, 2003 | 11:20 PM
25THRSS's Avatar
five7kid, just sent you a pm, but it said your mailbox is full. Can I buy this stuff off of you since you are a dealer?
scottmoyer
Jan 12, 2014 06:25 PM
cal30_sniper
May 24, 2012 09:16 PM
Saculia
Oct 7, 2009 11:58 AM
WickdEye
Sep 3, 2009 08:38 PM
87kevroc
Feb 12, 2003 06:45 PM
