Rear end oil change?
Old Jul 13, 2003 | 06:15 AM
Briansz28's Avatar
Do I have to take off the cover the drain the old oil out? I can't find a drain plug. If I take it off, do I need a new gasket or just use RTV?
Old Jul 13, 2003 | 08:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, take the cover off, and the fluid falls out.
The fill plug is in the pass side of the center section about halfway up.
Make a point of looking at your gears while you're in there, count the teeth or find the stamping on the edge of the ring gear, help stamp out useless "what gears do I have" posts in advance with equally useless "codes" replies.
I usually use just the "tubular style" of gasket.
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
