Dana's Probuilt trans almost in!
Old Jul 17, 2003 | 08:23 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
It's going in pretty good, almost ready to let the car down from the stands
Is there anyway to make sure I got my TC in far enough on the spines? with the trans bolted up to the engine, the TC spins easily and there is only about 3/8" of clearance between the TC and the front of trans...
What do you guys recommend for trans oil in a performance trans?
Old Jul 17, 2003 | 10:44 PM
Pro Built Automatics's Avatar
Check the clearance between the flex plate and torque converter with a feeler guage. It should be between .090 - .125, if it is more "call me". The fluid you want to use is the Mobil multi-purpose Dexron III, if you cannot locate this, then use Aamco or AC Delco Dexron III to mix with my Pro-Fluid at a approximate 50 - 50 mix.
Old Jul 18, 2003 | 12:38 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
is that .125 of an inch?
in other words no more than 1/8" between the flexplate and the TC?
I am just a few thou under 1/8" clearance..
what happens if the clearance is too large?
Hawk312
Aug 22, 2017 08:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Hello, Michael
Aug 20, 2015 03:19 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
