beater question
Car: 87 formie
Engine: none
Transmission: none
beater question
hey mods u think i can get a few replies before u lock this? its for my friends probe, its a 5 speed that wont go in reverse but all others work perfect. i dont know anything about manuals and he cant find any probe tech web forums (go figure
what should i check? shifter cable? or is the reverse gear itself most likely blown? any info would be greatly appreciated
thanks
) what should i check? shifter cable? or is the reverse gear itself most likely blown? any info would be greatly appreciated
thanks
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
either gear or synchronizer is gone, rule out linkage if is external linkage type tranny by putitng car on lift and looking around, i had a dodge omni that i had to rig linkage for tranny with coat hanger,. so..
it worked though
try search for ford sites on yahoo and google search engines
good luck
it worked though
good luck
