Okay a question about manual valve bodies in an auto.
Old Jul 26, 2003 | 02:34 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay im either going to get my 700 r4 beefed up or go to the t56 but need to find out some things first oky if my 700 r4.Has the transgo manual valvebody how do i shift do i go to first then to second then to overdrive then to drive?Also i want to drop in first gear at 2000 rpm or more a couple of time's in 1st can i do that with a manual valve body does do you shift just like a stick car but with out the clutch.Can i shift from first then let the rpm go back up and then shift to second or as soon as i pull it out of first does it go straight to 2nd?If i cant drop in first at anu rpm i chose or shift like a stick car then im probally going to go with the t56 or t5.
Old Jul 26, 2003 | 08:19 AM
ede's Avatar
ede
pretty much the same as a manual trans. read your PMs.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
