3.73 or 4.10
Old Jul 24, 2003 | 02:26 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
3.73 or 4.10
I have a 86 Iroc with a 355, AFR heads, fully done LTR setup, Long tubes, Xtreme grind 224/230 duration and 503/510'', 3.73 auto, blah, blah, blah.
I WILL be switching to a 6-speed and have access to a complete 4.10 rearend with relocation brackets, aluminum cover, etc. (4th gen).
So my question is stick with the 3.73 with the 6 speed and buy adapters for my Vette wheels and just put on the disks from the other rear or go 4.10s so I will not need adapters and have a steeper gear.
Chris
Old Jul 24, 2003 | 08:38 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
4.10's
Old Jul 25, 2003 | 05:55 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
4.10
6th gear is so steep on a T56 that you could get away with a 4.56 and still get decent mileage.
Old Jul 25, 2003 | 05:59 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Agreed.....4.10 is the perfect gearing for a T-56.
Old Jul 25, 2003 | 07:12 PM
Stingraye's Avatar
Car: 1986 Trans Am
hey what would you guys say about putting 4.10's in a transam with a T5? I was lookin into it, and i think i'd only be runnin like 2450 rpm's at 70 MPH. And I can get the richmond 4.10's from a guy for $20, so i'm thinkin of takin my 3.23's out for them. What do you think?
Old Jul 26, 2003 | 03:24 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I say it depends on what you do with your car.
I say 3.73's for a car that's driven around a lot. 4.10's or higher for a car that is not driven around much, mostly raced.
You have to keep in mind that yes, the 6th gear will allow you to get decent gas mileage on the highway, even with 4.10's. However, the 4.10's change the normal operating range of the car. With 4.10's, you will never NOT be in the power band. Now this is lots of fun and all... but there is a problem with that. Terrible gas mileage around town, especially if it is a torqey TPI car, because you will ALWAYS be around 3000+rpms, where it makes the most power and sucks the gas down.
I only say this, becuase I never realized that it had such an effect around town. I thought it only mattered on the highway, and the 6th gear had me covered. I like my 3.73's.... 4.10's would def be faster and more fun, but 3.73's suit my needs better... in the end, it's all about YOUR needs.
Have fun.
6speedIROC
16
Mar 15, 2023 08:33 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
S10K20
Oct 7, 2015 06:45 PM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
