Is this normal for a limited slip?
Old Jul 28, 2003 | 05:37 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
On my 84 Z28, which has a 3.73 limited slip rear axle. Sometimes it only spins the drivers side, and sometimes it catches both tires, this is normal isnt it?
Old Jul 28, 2003 | 06:36 PM
Momar's Avatar
It is normal when the limited slip(posi) is wearing out.
Ben
Old Jul 28, 2003 | 09:12 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
dont give up hope yet. mine was doing that, i changed the fluid, no more one wheel wonders. dont forget the posi additive
Old Jul 29, 2003 | 02:32 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Limited Slip applies traction to the wheel thats sliping, so at times its going to be one wheel or the other depending on the road surface. Both wheels are not getting traction 100% of the time, the stock rear is not a locker.
Old Jul 29, 2003 | 06:40 PM
Momar's Avatar
Thats not quite right. There is always power applied to both wheels in a limited slip. But... it slips if enough force is put against it because the power is applied through clutches in the carrier. For instance, when you are going straight there is power applied to both wheels, but if you go to turn it allows a "limited" amount of slip so that one wheel can turn faster than the other without binding. If the posi is good it and its not because of bad fluid like mentioned above then you should pretty much always spin both tires unless you have one of the wheels clamped down somehow so that it overpowers the clutches. I would try changing the clutches first and put "GM" posi additive in it and see how it works. If it still gives you one wheel peel then the posi is going out.
Ben
Fanatic1074
Oct 3, 2022 05:57 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
