Vibration
Old Aug 4, 2003 | 04:29 PM
kc chief's Avatar
Vibration
My IROC has a vibration that starts about 45mph. It's pretty violent by 65mph. I replaced the axles, thinking they were bent, but no. I rebuilt the rear while it was apart. My question is, on jack stands, the driver's side rear would bounce up and down. Would a out of balance drive shaft transmit the vibration to just the one wheel? I think it would because it's an open differential, and that's the wheel that was turning. Oh yeah, tires have been balanced, and the wheels are true, so that's not it. The U joint is tight and has no give. Ideas? How much to balance a drive shaft, and do you have to take off the torque arm to get the shaft out? Would it be better/cheaper to try to find a balanced aluminum shaft?
Thanks,
Scott
Old Aug 4, 2003 | 06:13 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Yea, the drive shaft could be the culprit. I had a very bad vibration in my 82 and it turned out to be the drive shaft. The company that made me a new one said the General uses junk tubes for their drive shafts. He showed me the size of the weights on my old one and what the new shaft had on it. It was amazing, the car is smooth all the way through top end..
Take your shaft out and have a reputable drive line specialist look at it put it on their mach. to check its bal..
Good Luck..
cc82Z-28
Old Aug 4, 2003 | 10:01 PM
kc chief's Avatar
Thanks for the response
Does the torque arm need to be removed to take out the driveshaft?
Old Aug 5, 2003 | 12:41 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
no
Old Aug 5, 2003 | 07:43 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
No, it does not. It's just a little close under there, but you can pull it out. Also mark the yoke at the rearend so as to put the drive shaft back in the same position it came out, or as it is called backe in phase I believe.
cc82-Z28
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
