Clunk?? Torque arm bushing?
Old Aug 5, 2003 | 09:21 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I've been trying to track down a clunk in my car...
I know you're not really supposed to "down shift" an automatic when rolling, however my car should be able to do a little better than it has lately...
When I go from D to 2, at virtually ANY speed, no matter how fast, it clunks. I mean, I can be doing 10 mph, but if it is in drive and I shift down to 2, it makes a loud clunk in what sounds to be the tail of the tranny. I have less than 200 miles on a new tranny mount and new motor mounts, so I doubt the tranny is shifting too much..
I have also checked both U-joints and they are 100%.
My torque arm bushing is dead... could that be the cause? My guess is that the torque arm is hitting something when I shift down.
Any ideas?
Old Aug 5, 2003 | 11:00 AM
ede's Avatar
ede
look at the trans mount and fix your TA at the same time.
Old Aug 5, 2003 | 12:19 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Yeah that clunk is the torque arm shifting in the bushing bracket. Replace the bushing and you should be fine.
Old Aug 5, 2003 | 04:25 PM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
Yes it is definitely the bushing. I've just recently replaced the one on my 89 Iroc. Be sure that you get both pieces though(inner and outer). The outer one should cost $15 and the inner one should cost around $25. It is a b*%!@ to put in though. You will have to remove the cross member that the tranny mount bolts to and lower the transmission and maybe even pry the tail of the transmission over to the passenger side as it is a very tight fit, but it can be done with a little persuasion.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
