Why not make a retro-fit bellhousing?
Old Aug 6, 2003 | 02:25 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Instead of having to go through all the issues with putting a t-56 in a 3rd gen, why doesn't someone make a bellhousing that will bolt up to the t-56 and retain the stock clutch, pressure plate, flywheel, master and slave cylinders?
I'm sure its feasable.
wouldn't make swapping a T-56 a whole lot easier
simply the transmission, a bellhousing, and a crossmember
Old Aug 6, 2003 | 03:03 PM
mjpell's Avatar
retrofit
Well, we're close. We have an input shaft, bearing retainer, adapter plate, and bolts that'll allow a '96 era T56 to bolt right into an early GM application. Pull out the old Muncie (26 spline), and stuff in the T56.
The kit is $600. Add an elec speedo, shorten the driveshaft, modify the crossmember, and you have a 6sp.
I'd have to check on using this with a 3rd gen though. I know Forte is working on it, just don't know where he is with it.
Old Aug 6, 2003 | 03:05 PM
StealthElephant's Avatar
Car: 87' Iroc
The Tremec aftermarket t56 has built in option for mechanical speedo and VSS, and can be drilled to mount directly to a t5 bellhousing, i think it's like 2200$
Old Aug 6, 2003 | 05:41 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Well for 86-92 Cars, that wouldnt help any, the 93-97 setup will bolt right to the factory engine, spohn makes the crossmember, and it doesnt require modifying the driveshaft or torque arm.
Old Aug 7, 2003 | 06:00 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I believe there is a guy in California that makes a bellhousing like you want. Bob something...buddy bought a bellhousing from him to put a T56 behind a Oldsmobile engine.
This guys kit uses a std. clutch. I think the issue would be that you have to shorten driveshafts and such because the bellhousings appear to be the same thickness of the T5 bellhousing. I would rather just use the LT1 stuff...as I am currently doing. I don't see a whole lot of extra pain going this route vs. retrofiting T56 hardware. Clutches are more expensive...but not too bad.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
383backinblack
Aug 15, 2015 06:36 PM
z28addict8490
Aug 7, 2015 08:48 PM
