Flywheel Help
Old Aug 7, 2003 | 06:46 PM
rccm's Avatar
Flywheel Help
Swapped 305 for 350 in 1988 TPI. used original T5 tranny and flywheel. Are these flywheels interchangeable or should I have purchased new flywheel for the 350? Since GM didn't make a 350 and T5 combo is there a source for flywheel? Also, parts catalogues talk about internal or external balancing. What does that refer to?
Old Aug 7, 2003 | 08:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the flywheel you had bolted up, then you're good to go. It is not possible for a 88 flywheel to just bolt up to any motor that it isn't correctly balanced for.
The correct source for a 350 swap is a 305 flywheel. i.e., what you have.
The 400 small block and 454 big block cannot be internally balanced, in their stock configuration; there isn't enough room inside the block and its moving parts to fit a large enough counterweight. Therefore some of the balancing for them must be done by the flywheel or flex plate, and the harmonic balancer.
The 87-up 305 & 350 are internally balanced; except that their crank flange is absolutely round (for the rear main seal). The earlier generation of 350 and 305 had a small balance weight made into the crank flange, and so was not perfectly round. The flywheel you have has a very small "unbalance" that is equivalent to that older one. It is the same for a 350 or a 305, which is why a 305 flywheel balances a 350 perfectly.
Old Aug 8, 2003 | 12:03 AM
rccm's Avatar
305 flywheel bolted right up to the 350 so we're good to go. Thanks for the help!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
