700-r4 shifts to soon?
My car shifts from 1st,2nd.3rd way to early. It makes it a dog off the line. If I put it in low it blasts off like it should. I have adj. the tv cable. If i put it in OD and go easy it will shift to OD @ 40mph. Help.....
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
My 700 did the same thing. There is a fix. There are governor recalibration kits you can purchase. Jegs.com This kit allows you to change the shift points. Another problem you may be having is that the tv cable is worn and won't stay adjusted. Thats what happened to mine.
darwinprice
17
Oct 11, 2015 11:51 PM
