Something's not right
Old Aug 8, 2003 | 12:28 PM
dschweihs's Avatar
My 92 Firebird with a 305 TBI won't go into gear. It happened over the course of about two days. At first the shifter felt loose. Then, I had to try a few times to get it in drive. Now, it thinks it's in reverse whether it's in park or 1.
I don't know a whole lot about automatic transmissions, but it seems to me like the problem might be with the shifter rather than the transmission. When I used to be able to get it into drive it would run out fine.
I would appreciate any help. The motorcycle won't substitute very well in the rain.
Old Aug 8, 2003 | 12:49 PM
chefdan1's Avatar
just happened to me. go under you car and your shifter cable should be loose or completley off. there is a clip that holds it on and it probably came off.
