HELP! 5 Speed Won't engauge w/ new clutch
Old Aug 11, 2003 | 10:10 PM
ssullivan777's Avatar
I need help! I have a 91' RS 3.1L 5 Speed.
Just installed new clutch kit. and now it seems as if the clutch is not working.
Transmission will not shift into gear. You can try all gears, no luck. Reverse Grinds when you try it.
With the engine off, it seems as if the transmission goes into gear even when not pressing the clutch.
No problems while installing the clutch, I don't have any idea what to do.
Old Aug 12, 2003 | 08:10 PM
laiky's Avatar
The clutch is not disengaging. You may have the wrong clutch, the throw out bearing may be installed wrong or the fork might not be on the pivot ball correctly. it is also not uncommon for a failing Master slave assy to go south the minute it is touched (murphy's law of mechanics)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
InfinityShade
Sep 18, 2015 08:32 PM
