What does it take to convert a drum rear to disc?
Old Aug 13, 2003 | 10:06 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Transmission: 700R-4
I'm looking for a better rearend to go behind my 383 other than my 2.77 9 bolt. I see plenty of drum rearends for sale so I'm wondering what all needs to be swapped out to get it over to rear discs?
Old Aug 15, 2003 | 05:40 AM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Beuler...Beuler
Old Aug 15, 2003 | 07:02 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
not much, not to sound mean but use the search button. its been done and there is even a detailed thread
Old Aug 15, 2003 | 08:33 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
do you need to swap just the axles or is there anything else?
Old Aug 16, 2003 | 08:19 AM
Engine: ls1, LB9
I never did the housing swap but, from what I have seen is old posts. you need to cut the top of the axle flanges off and drill the 4 bolt holes to mount the caliper mounting plate. I had used my old drum axles in a 84 disc rear with no problem. I read on here though that some discs (factory ?) will not clear the flange on the end of the actual axle. I guess If you needed to a machine shop could turn the outside of the flange to fit inside of the disc and the problem would be solved
Old Aug 18, 2003 | 08:22 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Well you said a better rearend, did you want just disc brakes, or a stronger one as well? http://www.moserengineering.com/ should be able to help you out.
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Warlocksirix
Sep 3, 2015 12:26 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
3rdgenparts
Aug 6, 2015 09:03 AM
