Need help with vibration when accelerating.
Old Aug 16, 2003 | 10:22 PM
Z_Ghost's Avatar
Just dropped in a ZZ4 motor with a SuperRam on it and the aftermarket T-56 trans in to my car, I used Spohn’s cross member, torque arm and driveshaft.
I have the pinion angle at 0* and do not feel any binding in the driveshaft when I rotate it by hand, but when I drive the car and go more then 20% throttle then I get this really bad vibration. At cruse speeds it’s not there and when taking of at less then 20% it not there. Today I ran it to 45% throttle and 4500 rpms and once it got above 3500 it seemed to smooth out.
So what could be causing this, anyone have any ideas?
I sent Spohn an email Wednesday but still have got no reply back yet.
Old Aug 17, 2003 | 12:54 AM
Odyssey's Avatar
Well let's see.... the vibration changes in correlation with engine speed. That would indicate to me, that something's not cherry with the engine. Check your harmonic balancer maybe ? Your accessories ? Belt ? etc etc ?
Old Aug 17, 2003 | 03:15 AM
Z_Ghost's Avatar
That's what I am starting to think and seeing as I have a little bit of a cooling problem I wonder if it might be the water pump.
It's an Edelbrock that was on the car and it did sit around for a year, might be the bearings are going out.
Thanks for the idea :hail: Odyssey, I have been kind of obsessed with the pinion angle and I think I got tunnel vision.
Old Aug 18, 2003 | 07:53 AM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Engine Vibration
You should not have Zero Degrees of pinion angle. Even if the vibe is gone you should readjust to -1 to -1.5 degrees pinion angle or you can ruin the u-joints. Also, if you have not done it yet, you should have the Driveshaft balanced. It only cost about $50 and provides peace of mind.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
