Rear end swap info
Rear end swap info
89 iroc w a original 2.77 9 bolt disc.... pinion bearing is humming....
im saving up for a moser ford 9 but just incase the 9 bolt die, can i swap a 10 bolt disc rear out of an 84 trans am (not sure if it was the original rear) into my car. it does not have the alum prb style rear calipers.... they are the earlier model.... think its pre 89 style.... i know the rear will physicaly bolt up, but am i gonna need anything extra for the brakes.... are they the same line size and thread will the e brake bolt up correctly... (not that important) is my current master cly/prop valve correct....
thanks in advance
thanks in advance
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
