9-bolt pinion depth....with 3.90:1 gears??
Old Aug 18, 2003 | 11:23 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I need the pinion depth spec for the 3.90 gears in the 9 bolt BW rear.....please help...
Old Aug 18, 2003 | 12:22 PM
ede's Avatar
ede
it differant for each gear set. it should be etched on the pinion and the back lash etched on the ring gear.
Old Aug 18, 2003 | 01:02 PM
Car: 1989 Iroc-Z
Engine: 350ci SBC
its not
Old Aug 18, 2003 | 02:10 PM
ede's Avatar
ede
then reuse whatever shim is under the pinion bearing now and there's a very good chance your back lash and contact pattern will be right, or at most only off a .001 or so on the shim.
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
