T5 Speedometer Drive gear
Old Aug 18, 2003 | 04:16 PM
tpi_roc's Avatar
Can anybody give me a quick run down of what I'm going to face changing the speedometer drive gear in my T5? Do I just remove the tailhousing and replace it or should I expect a headache?
Anybody know of a tech article maybe even with pictures anywhere? Thanks!
Old Aug 18, 2003 | 04:19 PM
BADBIRD009's Avatar
ABIRD4U2NV did it in 10 minutes the other day.
Old Aug 18, 2003 | 04:22 PM
tpi_roc's Avatar
Great that much is good
But how did he do it?
Old Aug 18, 2003 | 05:00 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
TPI ROC, to change the drive gear you must take the tailshaft off the transmission, its 4 bolts. the gear is on the shaft of the tranny. I haven't done it, the gear badbird is refering to is the driven gear, on the VSS, I change it in 10 minutes. But yes you are correct to change the drive gear you must take the tailshaft off.
Old Aug 18, 2003 | 05:02 PM
tpi_roc's Avatar
The driven gear is very easy I can see that being 10 minutes worth of work, heck i've done it twice already before i realized i had a 8 tooth drive gear :sillylol:
I realize the 4 bolts for the tailshaft, Maybe even the shifter ... ?
Getting into it im not afraid of, i just dont know and haven't seen what kind of things i'll have to go through on the inside. It can't be on the shaft as its a tiny worm gear, not like the big one wrapped around the 700r4 shaft
Anyways Im still on the lookout for information, anybody who knows anything fill me in
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jharrison5
Aug 19, 2015 05:53 PM
