speedo wrong
Old Aug 25, 2003 | 08:47 PM
kbcattle's Avatar
speedo wrong
I just finished swapping a 1988 350 into my 1989 2.8 car. I swapped the engine trans driveshaft and rear along with the gauge cluster all from the same donor car. I took the car for a drive and I'm sure the speedometer is running high by 5-10 mph at 70 mph. Is there something else I needed to change or could something else need recalibrated after a swap?
Old Aug 28, 2003 | 11:14 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
If the rear is different ratio, the speedo gear has to be changed.
Old Aug 28, 2003 | 01:12 PM
kbcattle's Avatar
I did swap in a different rear with a different ratio but I also swapped in the tranny that matched with it. Am I wrong or is the speedo gear in the tail of the tranny and if so it should be correctly matched. If I am wrong could you tell me where the speedo gear is.
Old Aug 31, 2003 | 11:20 PM
TA5LiterHO's Avatar
It is in the tail. One side of the gear is around the tail shaft and the other part of the gear is what sticks through the tail casing. I just recently switched from auto to manual and had the same problem cause I have 3.73's and the speedo gear in the trans was geared for 3.42's.
Old Sep 1, 2003 | 07:53 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
there is a speedo box (can't think of the name)very small chance on this being whats wrong well, long story short it is mounted to the same bracket as the ecm so if you pull it down there you go, that is the only other thing I can think of right now. since the trans and rear are from the same car. unless that doner car was off too?
Old Sep 5, 2003 | 11:12 PM
TA5LiterHO's Avatar
Very well could have been changed in the donor car. I have a cable driven speedo, so I can't program mine. Have to change the speedo gears.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
