Rear End Oil Change Instructions
Old Aug 27, 2003 | 11:03 AM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Can someone post a thread connection on how to change/add oil to the rear. Photos would be great. I have a BW 9 bolt and I am getting some vibes. I want to make sure it has the right fluid level. Also, if someone has a part number or supplier for the anti-slip fluid that is supposed to be added, please send that too.
Thanks,
Scott
Old Aug 27, 2003 | 11:32 AM
armac's Avatar
Car: 83 ta
to just check the fluid you pull the pipe plug on the pass side of the diff. changing the fluid get a new cover gasket pull hte cover replaced and refill. the limited slip fluid should be used but no additives should be for the f-body rear ends.(per the factory shop manual)
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
