trans problem any help?
Car: 87 z28
Engine: 5.0
Transmission: t5
ok so today i am driving around and something happens to my clutch pedal when i tryed to disingage the clutch i heared a pop the plead goes down but the clutch is still engaged now the pedal still comes up after its pressed but it dosen't seem to move the clutch what could it be and how much would something like this cost top get fixed? any help is greatly apreciated.
Transmission: 4L80E/4L80E
Tell us more about your car (year, engine, etc.).
Does the pedal provide any resistance when you push it down now? I'd guess you lost either the cable or hydraulic cylinder (depending upon which type of clutch mechanism you have).
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
$40 per part to replace. Not that expensive. I used new ones when I did my tranny swap because the used ones i had didnt disengage the clutch.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
