light flywheel vs heavier flywheel
Old Sep 3, 2003 | 05:09 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i have two differnt flywheels, one is a lighter 16 lber the other is a 25 lber, the 16 is in there now, should the car be faster et and mph wise at the track with the lighter one?
Old Sep 4, 2003 | 05:54 AM
ede's Avatar
ede
yes for all out racing applications a light flywheel is prefered. for street you'd want a heavier piece to maintain or hold energy while you slowly shift, as compared to racing.
Old Sep 4, 2003 | 03:26 PM
Pro Built Automatics's Avatar
The car will be quicker when it is in gear on acceleration with the light wheel. When you power shift the heavier wheel will be better, but if you do not power shift then the lighter will be better and easier on the transmission. Leaving from a stop light is easier with the heavier wheel. If you road race then the light wheel is superior. As you see there are advantages for each depending on the different situations.
Old Sep 4, 2003 | 04:38 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
well since its my daily driver and i race it on friday nights whenever i can the lighter one is probably my best bet when im at WOT bangin through the gears?
Stangski09
Nov 14, 2015 01:27 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
fasteddi
Sep 10, 2015 09:32 AM
Trickskier
Aug 29, 2015 01:12 PM
Omega
Aug 10, 2015 12:46 PM
