Flexplate for TH350
Old Sep 3, 2003 | 08:36 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
Flexplate for TH350
Hello, i am going to do the TH350 swap in my iroc, i am wondering what flexplate to use with the th350 converter, i am going to use the TCI street fighter (241000) what flexplate does this converter use? and also do i need a 153 or 168 tooth flywheel? this converter is only compatable with a 168 tooth, if i convert do i need a new starter too?? if this converter isnt compatable, do you have any other suggestions??
Old Sep 3, 2003 | 08:41 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you use your stock 700R4 flexplate
Old Sep 3, 2003 | 08:47 PM
stevver84Z's Avatar
yeah thanks just figured it out, there are 2 different converters small and large bolt patterns, thanks
Old Sep 4, 2003 | 11:20 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I found that out a while ago too...my 406 stock flexplate has been bolted to a TH400, a TH350 and my 700R4...
84LsxZ28
May 17, 2020 02:21 PM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
89newfun
Sep 16, 2015 09:28 AM
roysatikas
Sep 7, 2015 08:08 PM
