T56 Identification
Old Sep 8, 2003 | 03:46 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
T56 Identification
What exterior cues should I look for to ID a T56. If these normally come with a tag bolted on the side like a T5, this one is missing. There is a bar coded sticker with some numbers on the top of the case. Can I cross reference those numbers? I can tell it's a LT1 model by just looking at it but have no idea what year. Can anyone help?
Old Sep 8, 2003 | 08:57 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
There's a sticker on the side that says what type of fluid to use. If it says Dexron IIe then it's a '93-95, if it says Dexron III then it's '96 or '97. Find the first gear ratio to see if it's '93 or '94-97 (2.66 for the later years, 3+ for '93.) Just put it in first and count how many input shaft rotations it takes to turn the output shaft over once. That's all I can think of....the only thing that's really important is whether or not it's a '93 trans, as the '94-97 are all identical.
Old Sep 8, 2003 | 11:06 PM
wesilva's Avatar
Transmission: 200R4
Thanks! That's a big help.
Old Sep 9, 2003 | 07:35 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Really? I didn't realize that about the Dexron III vs. Dexron IIe sticker, in fact I never even thought of it. When I bought my T-56 I was told it was a brand new unit (never installed in a car) but that it was the '93 style, however it's got the Dexron III sticker on it, so maybe it is a '96-'97? hmmm....very interesting!
-Paul
Old Sep 9, 2003 | 12:53 PM
TheGreatJ's Avatar
The sticker thing should only apply to used tranny's (i.e. out of a wrecked 4th gen.) Any trans MANUFACTURED after '95 (even new tranny's with the '93 style ratios) should have a Dexron-III sticker.
Old Sep 9, 2003 | 01:57 PM
quadgoat's Avatar
Car: 1992 Firebird
Gotcha, that makes sense, I thought of that after I posted my reply, I don't know for sure if it was actually purchased new and never installed but I was told that that was the case, and also told that it had the '93 style ratios. The tranny and bellhousing were AMAZINGLY clean so I'm assuming I was not lied to, and the '93 ratios are fine with me anyway, 6th gear is more usable that way, I tach right around 2k rpm in 6th at 60 mph w/ 3:73 gears, so it works out pretty well
-Paul
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
