speedo went tits up
Old Sep 9, 2003 | 01:01 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
speedo went **** up
ok well my speedo went **** up tonight, ive got a spare set of gears for the tranny, which i know is wahts wrong. but when i unbolt the one on the tranny will atf leak out, if so im just gonna wait and do it at auto shop at school,
thanks for any help.
Old Sep 9, 2003 | 11:21 AM
Squeeks83's Avatar
so no body can tell me if it will leak or not. dam.
Old Sep 9, 2003 | 04:29 PM
bicknese's Avatar
nope...it shouldn't leak...there is a seal there that will prevent that...unless it is bad as well....even then it won't leak much at all.
Old Sep 9, 2003 | 04:37 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It will leak when you pull the sending unit out or the tailshaft off; if it doesn't, it means you're very low on fluid...
Pete
Old Sep 9, 2003 | 06:53 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
it will leak some fluid, not for long though, just dont be under it when you pull the housing
Old Sep 10, 2003 | 12:27 AM
Squeeks83's Avatar
ok so the invertor broke off the needle inside he gears, so i poped in new gears, it was off by about 10mph, so i swapped the other gears back in, they seemed to work, but they ended up not working, so now i have to go order a new invertor from GM which costs 53.99.
and yes it does leak tranny fluid.
Old Sep 10, 2003 | 01:11 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Hey Squeeks83, it's a G-Force T-5!
And yes, it'll leak, but I see you found that out!
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
