rusty rotors...
Old Sep 14, 2003 | 01:12 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
rusty rotors...
The rotors that came with the brake setup for my rear where rusty when i got them. They didnt have any scale on the surface sweped out by the pads but it did have some surface rust. I sanded most of it off with some fine grit sand paper and the brakes seem to work fine but should i still have them turned to get a more uniform surface laid down or is it still ok to jsut let the rust wear off on its own?
Old Sep 14, 2003 | 10:32 AM
Morley's Avatar
As long as there aren't any grooves worn into the rotors it should be fine.
Old Sep 14, 2003 | 03:27 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The problem with used rotors is you don't know if they are true. If they seem to work fine then they probably aren't warped, but it maybe a good idea to get them turned for a few bucks to make sure the surface runs true. Very light surface rust is not a problem. Just wipe it off. When it starts to pit the surface, then you must turn them.
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
aaron7
Sep 30, 2015 09:15 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
RyanJB
Sep 14, 2015 03:39 PM
Winchester1094
Aug 18, 2015 10:23 AM
