Truck TH700R4
Old Sep 14, 2003 | 11:02 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Truck TH700R4
Hey, I just found a Th700, it comes with the torque conv,
'towing pack' , and shift kit.
Would it be a bad choice for the camaro ?
since gears r the same ..
The guy built it up for this snow plowing pick up.
thx 4 any info.
Old Sep 14, 2003 | 11:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Should be fine, except the TC maybe the opposite of what you'd want, there's no difference in a truck trans.
Old Sep 14, 2003 | 06:36 PM
Steve86TA's Avatar
Car: To many to list
The tailshafts are different.Is it a 4WD trans?I thought the 4WD was different than the 2wd version?
Old Sep 14, 2003 | 06:45 PM
Spectre's Avatar
Engine: 3.0L/183
ya.. I figured the torque wouldnt be valid 4 my application.
tnx 4 the info
Old Sep 14, 2003 | 11:14 PM
camarodude91's Avatar
I have a 700 from a van and all i had to do was change the tail shaft cover so the torque arm would bolt up.
Old Sep 15, 2003 | 06:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 4WD output shaft is the same; the extension housing is different.
But of course, any extension housing other than a Camaro/Firebird one won't work; you'll have to re-use your existing one on whatever trans you get, if you get a random used one from somewhere out of something besdies one of these cars.
camaronils
Sep 20, 2015 02:57 PM
BLK87Z
Sep 18, 2015 11:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
david068513
Sep 18, 2015 10:36 AM
Amillionoh7
Sep 11, 2015 11:36 AM
