Switching to carb, TC lockup ?'s
Car: 87 Trans Am
Engine: 350 Super Ram
Transmission: Level 3 Raptor 700R4
Hi,
I've done a search on this topic but couldn't find exactly what i was looking for.
I'm going to be switching my 305 TPI to a carbed 383 (no ecm), and i have a few questions regarding a homemade TC lockup switch.
1. Will wiring the switch to the ALDL connector work when I don't have a computer?
2. I've read that locking the torque convertor manually shortens the life of the transmission and TC. What causes this?
3. If I wire a toggle switch (for highway use), and an n/c momentary switch (on the shifter for drag racing) in parallel, could I avoid some of the negative effects on the transmission by only holding the lockup switch inbetween shifts when racing, and allowing the tranny to shift with the converter unlocked?
thanks alot,
nick
thanks alot,
nick
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Switching to carb, TC lockup ?'s
Originally posted by notaustin83z
Hi,
thanks alot,
nick
Hi,
thanks alot,
nick
2) not that I know of if used properly. if you only activate it in O/D while cruising at a steady speed then no harm done.
You'll need to buy a switch for it. A few companies (look in jegs and summit) make them ...they're either vacuum or electronically controlled they're around $50
someone972
Aug 30, 2015 12:52 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
