Pinion Seal + ?
Old Sep 25, 2003 | 09:51 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Pinion Seal + ?
Is there anything thing else I should replace while installing a new pinion seal? Any while I am right there's?
Old Sep 26, 2003 | 09:13 PM
RP1987GTA's Avatar
if you don't want to be replacing bearings or worse be sure you understand how to set the bearing preload on that pinion BEFORE you take it apart to replace that seal
Old Sep 27, 2003 | 06:38 AM
ede's Avatar
ede
when you replace the seal you won't be "in there" to replace anything else. like was said above do a bit of research before you jump in and replace the seal
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
