dakota digital switches on/off?
Old Sep 28, 2003 | 03:51 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I need some one who has one on a tpi car ONLY! to reply I just need to know how you have your switches set. I followed the instructions but, I am not getting any singnal out. just want to double check that I have it hooked up right. if so then I guess I get to check out the sensor its self
Old Sep 28, 2003 | 04:19 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
No offense, but I really don't feel like typing a bunch . I (and others) have made quite extensive posts/replies about this in the past. It's all out there, just do a search .
Old Sep 28, 2003 | 05:36 PM
Engine: ls1, LB9
I did a search!!! no where could I find any thing that specific. just abunch of how to hook it up posts. sorry you feel you won't type "#1=off, #2=off rest on till you test drive and calculate speedo calibration" maybe I should quit retyping all my post time and time again when I see you asking a very simple question. (I guess why did you wast your time even replying at all?) keep in mind t56 will not work with search eng. so you have to write very specific which does not work very well. It gets me how you can be such a jerk to write something like that! I only wanted to recheck my setup but you must be too good for that
:hail:
Old Sep 28, 2003 | 06:05 PM
viperwsu's Avatar
Car: 91 Camaro RS
Have you tried to search for SGI5? That should work, and will give you lots of threads on the subject. As for which switches on or off, that really depends on your speedo calibration.
if I remember correctly, switches 1 and 2 define how the signal is convereted, and the rest are the calibration. It's been a while since I messed with mine, but here is a pic I posted on of the many threads on this exact subject
the thread is
https://www.thirdgen.org/techbb2/sho...hreadid=180665
BTW, if you do ask a question, and someone tells you to search for it, don't reply with nasty comments. Nobody will want to help you. Just search for different things, and take the time to filter through the search results.
Old Sep 28, 2003 | 07:36 PM
Matt87GTA's Avatar
WOW .
I wasn't sure if you were aware that there exists MANY MANY a post/reply about this exact subject that likely already answered your question... I had no idea you had performed exhaustive searches prior to this and were at your wits end.
I'll just watch you sink next time I guess .
BTW, 1101000100 when I had 3.42s..... Haven't recalibrated since the 3.73s.
Old Sep 28, 2003 | 08:11 PM
Engine: ls1, LB9
thanks alot. thats all I asked even more . it just pisses me off when people spend so much time telling people to use the search button when they can just do what you just did.
viperwsu, I never thought to use ( sgi5 )
MantyZ28
Nov 8, 2015 06:54 PM
tglennon11
Sep 23, 2015 05:30 PM
earlpote
Sep 12, 2015 11:55 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Randomtask2
Sep 10, 2015 08:37 AM
