series 3 diff
Old Sep 30, 2003 | 07:24 AM
RallyeNate's Avatar
Car: 85 IROCZ
Engine: 305ci
series 3 diff
how can you tell what series a posi is? no gears came on it and it was out of a 98 Z28.
Old Sep 30, 2003 | 09:02 AM
ede's Avatar
ede
most likely i'm wrong but i thougth i read or heard all 4th gen rears were 3 series. the differance is the thickness of the flange the ring gear bolts to
Old Sep 30, 2003 | 11:18 PM
RallyeNate's Avatar
Car: 85 IROCZ
Engine: 305ci
what happens if you are wrong and it is a series 2 and i install 3.73 gears on the diff and start launching it at the track?
Old Sep 30, 2003 | 11:24 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
carrier
ede:
It's not the thickness, it's the position of the flange in relation to the ring gear side bearing.
If it is a 2 series get the thick gears if not get the regular gears ( they do make both).
Old Oct 1, 2003 | 05:43 AM
ede's Avatar
ede
ok thanks don, i guess i had it about half right in my head, i thought they used additional material in the mounting flange to move the ring gear. guess if i'd thought about it for a bit i know, even used, spacers and the differant gear thickness. well i never claimed to be anything more than a dumbass and i guess this proves it, thanks again
Old Oct 1, 2003 | 06:18 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
well iknow for a fact that some 4th gens had 2.73 rears... so it could be a 2 series carrier.
Old Oct 1, 2003 | 07:29 AM
RallyeNate's Avatar
Car: 85 IROCZ
Engine: 305ci
if the ring gear mounting flang is to thick-> could you shim the carrier close to the driver's side to adjust for the difference in thickness?
if the ring gear mounting flang is to thin -> could you buy the thicker ring gear set from SLP?
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
