burnouts
Old Oct 2, 2003 | 12:23 AM
tataconka's Avatar
Car: 1992 z28
Engine: 5.7
Transmission: auto
burnouts
Why does only one tire spin. What can I do to fix that?
Old Oct 2, 2003 | 12:50 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Get a SLP take off posi and put in it.
Go to there website, and search for zexel torsen.
Kevin
Old Oct 2, 2003 | 08:27 AM
MdFormula350's Avatar
yeah sounds like your posi is wore out or you never had posi to begin with.
Old Oct 2, 2003 | 10:15 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
first u gotta find out what rearnd u have, what gears are in it and if its posi or not. judging by the year (92) it most likely has a 10 bolt since GM discontinued use of the 9 bolt in 90. the gearing is probably 3.23s with limited slip (sounds like its worn out now). u can get an SLP take out posi but u wont be able to install it urself, a rear end tech will need to put it in, the carrier will have to be reshimmed so the gears align properly. so if ur gonna go through all the trouble of havin a carrier installed its probably a good time to get a set of gears for it, 3.42s will do the trick. now atleast u can put in a good posi and a nice set of gears at the same time and not have to pay twice to have the rearend worked on.
Old Oct 2, 2003 | 05:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
if its a b4c then he should have 3.42 gears and posi. he should pop off the diff cover and check this stuff out before ordering gears
Old Oct 2, 2003 | 06:06 PM
StealthElephant's Avatar
Car: 87' Iroc
jack ur rear up, put the car in neutral, spin the wheel, have someone count how many times the driveshaft spins. my rear had a metal tag hanging off the diff cover that said posi on it, my RPO code under the center console was 3.23, did the driveshaft/wheel check, yep, turned 3.23 times
Abubaca
Nov 5, 2016 12:22 PM
Thirdgen89GTA
Apr 11, 2016 02:07 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Cleotiz
Sep 16, 2015 08:02 AM
Amillionoh7
Sep 5, 2015 11:44 PM
